Re: 1971 Evinrude 9.5 Sportwin Tilt Problem
iwombat: when I try to shift out of reverse, it pulls the lower unit back up into the motor, so I think you may have that reversed, but I'm probably wrong. I followed imported_F_Rs instructions, and they make sense except it won't drop more than about 1/4 inch, not far enough to get a socket in.
To get at the water pump, put shift in reverse, remove the four hex head bolts holding the gearcase on, pull the gearcase down about 3/4" and you will see the brass shift rod connector inside. Remove the lower screw from the connector, then the gearcase can be removed from the motor. The water pump will be looking right at you, around the drive shaft...
As for the shift mechanism, I'm having trouble trying to figure out how to remove the shift lever so I can remove the right side cowling, as in your picture. Do you by chance have a step-by-step of how you did that?
Sorry for being such a newb. I just want to be able to do this kind of stuff myself. I'm a computer programmer, so you'd think I could wrap my head around this kind of engineering, but I'll tell ya, I sure feel dumb now.
The repair manual I got is pretty crappy too. I eBayed a $5.00 manual on CD that is supposed to cover the whole lineup of OMC motors for the latter 20th century. It is so generic in nature, that it won't walk me through the most basic of maintenance functions. It looks like it was hastily scanned from a library, and each page was delivered as a seperate file.
I think I'd better break down and get a good manual, should I try to get the original for this specific motor? Is a SELOC manual the best, or is the OMC preferred?
Thanks again for your time and help.
P.S. - I'll try rotating the flywheel tonight to see if that loosens her up. Thanks for the tip.
