Sat in storage for awhile---
about 4 years ago replaced fuel pump with 18-7350 Sierra Fuel Pump, all fuel lines, tank and plugs, blew out carb, new impeller. Tried to start it recently for the first time since i put in new parts and it would run only about 2 mins with the throttle set to start position. Fuel filter glass bowl kept emptying out, so retightened all clamps/hoses. Now appears to stay full, but still stalls unless I keep pumpin primer.... I also took apart the fuel pump earlier in year, it was a pain puttin back together and not pos't I put back together right...so obvi first response will be to replace it or check it which i'll do tomorrow...is the 18-7350 sierra pump the correct one to use, see link on iboats.com for pump page fuel pumps johnson 9.5. Also, what is the correct setting for low speed throttle needle from all the way closed (from the right), i messed with it a lil (its not closed right now just a lil off canter). Also engine runs rougher when cover is on...possibilities?? Thanks a lot, Ryan Aldrich
