Throttleman
- Joined
- Jul 3, 2007
- 3
I read the posts of Johnson 90s leaking oil from different places, but this is a new one on me. I just changed the lower unit oil (in the full tilt-down position), and within 24 hours, a small stream of fresh lower unit oil flowed out the exhaust port (behind the propeller).
Is there an overflow tube - did I overfill? (The fluid level was even with the upper screw). Is the casting cracked deep inside?
Will running the motor help swell the seal? Can the seal be replaced without removing the lower unit?
Please help...got a river trip in two weeks.
