Over Heating!
FLAT4FLOYD
HI I Have 97 volvo penta 4.3l I/O that started over heating. looking for trouble shooting help. thanks
FLAT4FLOYD
Re: Over Heating!
210+ was runing great 1/2 hour prior? checked water flow from bolth pumps with very little flow?
Don S
Re: Over Heating!
Did you check and/or replace the impeller? That is the first thing to check on any marine engine if it overheats.
FLAT4FLOYD
Re: Over Heating!
Thanks for the tip are you talking about the fresh(raw) water pump impeler. Will any thing stand out what do you look for?
Don S
Re: Over Heating!
The sea water pump impeller. NOT the engine circulation pump. (known in the auto industry as a water pump)
tic
Re: Over Heating!
The rubber vanes of the impeller will be shredded or torn off completely.. Bits of rubber will remain in the impeller housing and are probably all through your cooling system clogging things up now if that's what went bad.. You'll need to flush out the cooling system and install a new impeller, might as well order the kit AND the impeller itself , chances are good that if the impeller went bad it spun the metal inside the housing too... The good news is it's very easy to get to...
Dante04SRT
Re: Over Heating!
Ditto - I did my impeller last weekend. Fairly easy (in retrospect) and now the boat cools just fine!
FLAT4FLOYD
Re: Over Heating!
The impeller was shot. Only two of the vanes left, the rest gone. Replacing the impeller was very easy. Now on to the electrical truble Thanks again
