reeldutch
- Joined
- Feb 2, 2004
- 1,340
Re: only 3800 RPM at WOT - loss of power under load -- please HELP
when you are at wot you got to push in the key to activate the primer.
it has noting to do with the primerbulp.
when pushing in the key you will richen up the fuel/air mixture.squirting extra fuel into the intake manifold.
if it picks up for a short moment that means that you are running to lean.
if it bogs down even more, than your mixture should be about right.
check that out.
your idle rpm is fine.
if your fuel system is good meaning no air leaks
as you sound confident you dont have but did not verify it, and your fuel pump has good fuel pressure and your carbs are clean, you got to do the spark check with the timing light at wot.
see if the spark cuts out or may be you do have spark.
if you dont have spark we will have to troubleshoot the ignition system.
if you do have spark make shure your link and sync are correct and that your timing is set correctly.
check that out.
