Motor had sit for about 18 months, I put in my pond startred it ,ran sluggishly,so I removed carburator and cleaned it .Ran it in pond was
running great,but was difficult to start ,used starting fluid and wd40
would start right up. I took it to the local boat place and told them to tune
it up. They removed carb cleaned it($116).I took boat to the river for a little fishing, motor would not rev under load,would rev fine in neutral.Took boat back to dealer prepared to raise h---,dealer told me the mechanic had a heart attack shortly after I picked motor up,felt like a jerk. Dealer suggested that prop might have spun,bought new prop ($77) purchased new fuel pump
because I thought that might be the problem ($57).Put boat in pond, wouldn't rev under load,wouldn't start without starting fluid.Took boat out decarbed , ran compression check (90 on one cylinder,70 on other),put new spark plugs in gapped at .030,replaced tank hose and hose to motor .Put boat in pond ,wouldn't start with out starting fluid,wouldn't rev under load,ran for about 15 minutes around pond hoping it was trash from decarb procedure,no luck.Shut off motor removed air intake to check for anything obvious, didn't see anything,now motor very difficult to start,even with
starting fluid,dies when you put it in gear,revs ok in neutral after you finally get it started.
Any and all suggestions would be welcome.
I had planned on trading for a larger motor (40hp jet prop),but need to get
this one running or lose it in the river first.
Thanks
Thanks
