SuperNova
- Joined
- Mar 16, 2007
- 1,455
Re: Merc 5.7L LX with Governor???
I would like to weigh in here with some personal experience. I had an '86 wellcraft Elan 197 which originally came with a 205 hp 4.3 v6 and the 1.62/1 outdrive gears. I removed the 4.3 and installed a very high performance 350 with aluminum heads and intake, etc. I kept the original gears and the original distributor and TBIV box for the v6. I replaced the cap and rotor with the v8 ones. I ran everything from a 19p 3 blade to a 23 pitch 3 blade cleaver, including a 21p 4 blade s.s. trophy. I ran that outdrive up to 5700 rpm for extended periods(1.5 hrs straight sometimes). With the 19 and the 21 the boat didn't have any plane time, it just launched right out of the water onto plane, even with a full load. Up top it would hit 53- 5500 rpm and then I/d trim it to get the extra couple of mph and 200 rpm or so. With the 23 you'd start to notice some plane time with a full load of people, but it'd still run over 5000 rpm up top without trimming. I never hit a limiter and I nver had any problem getting onto plane. I even tried a 26p bravo 4 blade s.s. and could use it for skiing and tubing.
They tell me at the performance marine shop that the v6 ignition box is the preferred unit for performance as it has a more aggressive advance curve. I also set the base timing at 14d btdc. I swapped the outdrive for a 1.5 unit off a 26' wellcraft with twin 260's, put the 23 cleaver on it and with just me in the boat it was good for 74.3 mph on the gps at 5400 rpm, but with eight people in the boat it took a little while to plane and I sheared the teeth right off the upper gearset after about 15 dead water starts with a full load. Granted it was the light duty 1.5 gears (I tore the outdrive down and put the 1.5 h.d. set in for the guy I borrowed it from). I re-installed the 1.62 drive and it has been running happily ever since. The guy I sold it to is thrilled with it. That was 2 yrs ago.
Point is the problems you are having shouldn't be and I don't think its the ignition box unless it is known to be one with a rev limiter and then I would agree with Don that your tach is probably incorrectly calibrated. Also his advice is probably best for getting as close to the factory setup as possible. i was just trying to illustrate the point that things don't necessarily have to be factory conceived to work properly, but you do have to know what you are doing.
Stan
Stan
