oldpontoon
- Joined
- Jul 8, 2007
- 23
I have a 1983, 90 HP Johnson Seahorse hooked up to a 28 ft JC pontoon.
Gas is leaking. I found that is dripping significantly from one screw at a particular place. I'm new to this so I don't know all the parts of the motor..so I took pics for you to help me 1) identify the parts 2) give me a clue where the gas is coming from (broken seal) 3) is this a big job?
I took picture in sequence that zoom in, a placed an arrow pointing to the screw where the gas is coming from. It's at the bottom, really close to where the two parts that are circled (one is gray and one is tan) are bolted together. It's dripping quite bit, about a drop every 3 to 5 seconds when the motor is running. Is there a gasket between these two parts that could be dried out? is this a big job if thta is the case?
What is the gray part called? I apologize for being ignorant
Thanks for the read and the help.
