Gah - silly little mistakes.
iwombat
So I decided to do a decarb last night using the 1gal 1can method on the muffs. I start it up and run it for a few minutes, normal operations etc. fine. Shut it down, turn hose off, take a break. I come out for another run, start her up and . . .
la la
holy . . . I FORGOT TO TURN THE HOSE ON!
Only ran it for about 15 sec. No apparent damage, and it still pumps good. But, I'll be replacing an impeller tonight anyway.
D'OH!
Jimmy Jam
Re: Gah - silly little mistakes.
D'oh!!!!:p:D
Hey while your at it....how about changing mine!
wbeaton
It was probably still lubricated from the first round of decarbing, but I can see how it would scare the heck out of you. Good thing you caught it quick.
reload
Yea you could have had phone call while it was running.
samo_ott
No one is dumb enough to answer the phone and leave the engine running!!! :)
wbeaton
I'm sure iwombat isn't. Me...I've done dumber.
iwombat
Oh trust me, this is just one I don't mind posting about.
Scaaty
Idle with a moist 'peller for 15 seconds..means little...
luckyinkentucky
A noob question, but what is the " 1 gallon 1 can method"?
I just decarbed tonight, and left it in there. I had to hook up a nozzle that came off of the can to my vacuum pump. Looked like the nozzle on a bicycle inner tube. The can said to leave it in there from 3 to 16 hours. I assume that's ok since I'm leaving it in there overnight.
What's the 1 gallon method you spoke of?
iwombat
It's in the decarb faq, but it's basically mixing one gallon of premix (or gas with a vro) with one (or thereabouts) can of seafoam in a portable tank. There's variations on the theme involving using half to 3/4 can and dumping the rest in the carb bodies, etc..
chbailey
What about 5-7 seconds?
iwombat
I know it probably means little, but I'm heading out on 5 day trip next week. I take no easily preventable chances with equipment.
R.Johnson
According to this, you would want to change the impellor if you did a compression, or ignition test without cooling water on. 15 seconds? stop scaring yourself.
MikDee
Banned
15 seconds? I was cranking my 125 Force trying to see the marks, to set the timing for a few minutes at a time, never gave it a thought to put the hose on, Duh! and the impeller didn't look too bad, atall.
darrklim2
Thats not only bad for your impeller it is really bad for your starter.
iwombat
Well, it's done. Good thing too, I had a partially melted vane.
