1993 celebrity 4.3L
Thread starter- Joined
- Jul 2, 2007
- 53
1993 Celebrity 4.3L V6 only 350 hours
Got the boat at the shop with what started out as getting the battery cables replaced due to a very slow to crank motor. Cables were showing signs of corrosion and were putting up a lot of resistance. Things have progressed to my mech. finding water in the cylinders. He dried them out threw some plugs in it and fired it up. He put it in the water and after 5 minutes or so it starting hammering real bad with more water intrusion. Now he's got the heads off to look for cracks and visually they look fine. Head gaskets look fine. He's sending the heads to a machine shop for inspection next.
He's a little stumped. He said the crankcase took in about a gallon of water and that he's never seen a boat ingest that much water.
What else can we look for? He said the flappers are completely burned out to non existence but he said he's seen many boats from similar year and make, go without them with no problems.
Could the block be cracked internally? Doesn't leak water externally at all.
HELP!!!!
HELP!!!!
