LunkerClassic
Thread starter- Joined
- Jul 21, 2007
- 6
I'm a new boat owner, so bear with me on the terminology. The rod that goes through the tilt-tube on my outboard will push out when the wheel is turned, but will not pull back in. The cable seems to be moving back and forth fine but whatever linkage there is inside the rod at the end of the steering cable seems to be detached.
Is it possible to just remove the rod portion of the steering system and reconnect that piece. I've removed the rod from the tilt-tube but cannot figure out how to disassemble it any further.....seems sealed pretty tight.
I've attached a picture of what I'm describing....hopefully it works.
Any advice would be appreciated.
Aaron
Aaron
