Just Purchased 70's Model 9.5 Johnson That Has Sat For 2yrs. The Carb Was Caked With Buildup. Cleaned Carb To New Condition With Cleaner And Air. Purchased Oem Rebuild Kit. Installed New Float And Needle, Oring For Slow Speed Needle, Upper And Lower Gaskets. If I Pour Gas Into Carb She Fires On First Pull. The Slow Speed Circuit Must Be Issue. However Carb Cleaner Came Out Every Orifice Including The Small Pin Holes In Bottom Of Throat. The Only Thing I Haven't Done Is Pull The Larger Plug Off The Side Of The Carb. I Believe Whatever Is Behind There Is Clean Because Of The Easy Flow Of The Carb Cleaner When Being Sprayed. No Gas, No Run Please Help!!
Thank You Much
Thank You Much
