help johnson info wanted
broom
Hi , just got my first boat , It has a johnson 40 electric model No 40EL745 is the oil mix 50 to 1 ?? .The boat came with a full tank of petrol , is there any way of telling if it has oil mixed with it . or do i throw it away.Also how can i find out the age of the engine.Sorry last question the boat is a 15 ft broom ,is the engine big enough.
jtexas
Re: help johnson info wanted
50:1 is correct; 2-stroke oil is usually blue or blackish blue or greenish and 50:1 premix is a noticeable color; 1974 according to http://www.themarinedoctor.com/omcyears.pdf ; depends on the hull design & material - plenty of power for a flatbottom aluminum, maybe not so much for a wide deep vee fiberglass. How bout some pics?
Did they tell you not to run the motor without either submerging the lower unit or attaching a water hose flusher? Not to rev it up without the lower unit submerged?
Do you know how old the fuel is or if its been treated with stabil or seafoam or similar? That's a great motor but it will be sensitive to stale fuel.
Any maintenance history on the motor? If you don't know when the last water pump impeller change was, best go ahead with it now, and every 2 or 3 years. Also a compression test would be a good idea, gives you a baseline for future diagnostics.
welcome to iboats!
angus63
Welcome!!!!
Motor is 1974
If you don't know the mix or the vintage, use it in the lawnmower or bonfire.
Should push a 15' boat just fine
Yes the mix is 50:1
Enjoy
Good luck
broom
Thanks jtexas and angus63 , i ran the engine in a big barrel , after cleaning out the carb, not that easy had to remove starter motor and other parts to get to it.And i will use the petrol in my lawnmower for the next few years. The boat seems ready .Now i just need the nerve to push it off the trailor and pray. I put a picture of it in my profile .THANKS AGAIN FOR THE INFO
Chief101
Don't forget to put the plug in!
