FreeBeeTony
Thread starter- Joined
- May 15, 2002
- 3,997
Think I understand why my engine destroyed itself......
At the end of last season I replaced a lifter which obviously required the R/R of the intake manifold. From what I hear these manifold/gaskets are prone to leaks.
After looking at the tops of the pistons again and comparing last years plugs to this years I think I can defintely say this was running lean.........I actually took note of the plugs I took out at the end of last season and they were the desired tan color. When I dis-assembled the engine after the failure the plugs were near white.
The timing was 8* BTDC and the vacum was ~19 last time I checked at idle.
Is the only way to tell if you're running lean to read the plugs?
