No angle transom
gooseroller
What will happen if I mount a 70 hp evinrude to the back of my no angle transom on an 18 ft jon boat? will it plane? If not how much of an angle do I need to get it to preform properly?
F_R
Re: No angle transom
What the heck?? I have no idea what will happen, except I hope you have the kill lanyard hooked up and life jacket on. Just my first reaction.
Walker
Transom wedges are available. Check your local marine shop.
gooseroller
Can I use several sets of the wedges together, they are only 5 degrees per set so I would need 3 sets to get the required amount of angle on the transom. Anyone ever done this?
samo_ott
15 degrees is a lot of angle... 10 degrees should suffice. Try it gently and see what happens :)
WaterWitch2
I have a friend who just bought 10 or 15 degree (I think) wedges. I'll find out where he got them and let you know.
steelespike
With some caution try it with one wedge.The most that will happen is you can't trim in enough and it may porpoise or run high in the bow.then add another wedge.
