jgbutler1956
Thread starter- Joined
- Aug 2, 2007
- 16
I have stripped,sanded,painted,re-cushioned,new hardware,painted again, new gauges, drained foot, de-carboned, pulled heads, new gaskets, new plugs, new impeller, etc... I am worn out....now cleaning last 2 carbs...1st 2 carbs were clean... ran ring free in gas and seaform thru the carbs....before cleaning carbs, it ran, but not great.... after I get these carbs clean, can I run this motor if compression stays 90,88,90,72? When I cleaned the carbon off the piston heads, the cylinder walls looked good... no scoring, gouges, etc
No excessive movement ... do I need to go thru setting timing, etc.?
