Trouble Starting w/o Starter Fluid
boatgrunt
94 5.7 Merc Alpha I - I have read Don S' post on troubleshooting starting issues but can't quite pinpoint my problem. I have trouble starting the engine when it's cold. I have changed all the plugs/wires and am confident that I have good spark. I am getting fuel into the carb as well, but it seems that when starting the engine cold at the dock, I inevitably need starting fluid to get going. Once the engine warms up, she runs beautiful and will start again with one turn of the key. Do I need a carb rebuild?
firehog6305
Re: Trouble Starting w/o Starter Fluid
sounds like you have a choke issue, is your boat a manual choke, or hot air type??
Possibly,........
But,........
I'd Fix the Choke 1st........
Btw,....... Starting Fluid has No Place on a Boat................
thrasher
I have to agree with firehog.
You need to get access to the carb and remove the spark arrestor (looks like a chromed air filter on top of the carb) when the engine is cold and look down the inlet to the carb. You should have 2 butterfly valves in the carb, the lower one is the normal throttle valve, the top one is the choke.
When the engine is cold, the top butterfly should be closed (blocking the inlet to the carb, it won't completely close, but should be close to fully closed). If the butterfly is closed then the problem is unlikely to be the choke. If the butterfly is open, then either you have a defective choke or you are using the wrong procedure to start the engine.
You state that you have a carb, so when the engine is cold, before you start the engine, you should fully open the throttle twice by pushing the throttle control fully forward, then back to it's neutral position and fully forward again and back to it's neutral position. This does two things, the first is it will allow the choke butterfly to close (assuming your choke is automatic) and the second thing is that the accelerator pump will have squirted 2 doses of fuel into the inlet manifold which help a cold engine start.
You should then turn the ignition key and start the motor. Some carbed engines have the idle set faily low when hot, which often means the idle is too low for the engine to start when cold. This means that you may have to give a small amount of throttle when starting the engine from cold. Most throttle controls allow you to pull the throttle lever out and then move the throttle without engaing forward or reverse.
Hopefully some of this helps. Don't forget to put the spark arrestor back on at the end!! You only removed it to check the butterfly valve, not to use it like that.
Gary
180shabah
...I have read Don S' post on troubleshooting starting issues but can't quite pinpoint my problem....
OK you read it, which of the items did you check, test, confirm or eliminate???
Sounds like a choke issue to me, unless you are using the EFI starting method(hit the key and go). I know both of these have already been mentioned, but they are the most likely culprits so I bring them up again.
Or a car,
Or a lawnmower,
Or a tractor......
:p
boatgrunt
Thanks. I'll check the choke either tonight or tomorrow morning and post a response.
boatgrunt
Gary
Sorry for the late response. I checked the top choke valve, and it was "close to fully closed" when starting cold. Does that eliminate the choke from being the possible culprit? If so, then should a carb rebuild be my next stop?
Haut Medoc
Are you pumping the throttle twice & seting it at 1/3 before you start?.....
Do you get a good stream of fuel when you pump it?......:confused:​
Haut Medoc
If you are getting fuel stream when you pump, try putting a pencil in the plate to open it slightly....:)​
boatgrunt
Once the motor was running, I did see what appeared to be more of a drizzle of fuel. At full throttle w/o the engine running, I couldn't detect a fuel stream.
As instructed, I pumped twice and left the throttle slightly forward. All this being said, when the engine is warmed, she starts/runs like a champ.
Haut Medoc
That fuel stream will (should) only happen as the throttle is being depressed.....
Have a helper pump it while you watch.....;)
You did not say if it started cold using the method above......;)​
boatgrunt
I pushed the throttle all the way forward and then went to the back of the boat to look. Should it be a continuous spray?
No, using the above method, it still did not start after sitting for a couple of weeks. The method did work after she sat one night though. It's confusing because I can't understand the difference 1 night would make compared to 2 weeks.
Haut Medoc
No, only when the throttle is being depressed.....​
Fuel evaporating out of the fuel bowl......;)
Next time you want to start it after a few weeks, I would recommend pouring two ounces of fuel into the carb & then starting it......
You do need to verify that the accelerator pump is working, though.....
If you have no hesitation issues, it is prolly OK....;)
boatgrunt
Nice...so I can use fuel w/o having the same damaging effects as with starter fluid? If that's the case, I'll just carry a little squirt bottle of gas for the really cold starts.
Haut Medoc
Absoloutely!.....
Yer engine runs on gas, not starter fluid........:)
Ayuh,.........
I can see a whole New bunch of Safety Issues with That......................:rolleyes:
Might otta just Fix it............
Nandy
The biggest problem with the starter fluid is that it lacks the lubrication that you mix has, even worse, it will remove the little the motor already has if you use too much or too often. The method you mention will work fine. I had a friend with a similar problem. He made an adapter and will unhook the line from the motor hook it to his adapter, squirt some gas in the carb then hook the line again to his motor and start the motor. He did that until he blew a reed... then he fixed the reed and the carb.
Good luck!
180shabah
Nandy, there is no mix, this is a chevy V8.
Question, do the v8, still use mechanical fuel pumps? I know that the 4.3 by this time had all been switched to electric pumps. If you have an electric pump you can do what I did. I had an extra switch on the dash, so I ran a wire from it, directly to the fuel pump. Now when the boat has been sitting for a while, I just hit the switch for 5-10 seconds and the fuel system is primed. No cranking and cranking, just pump the throttle and turn the key.
Nandy
Duh! My bad, then using the starter fluid should not be a problem, however, is not he cure as multiple members has posted here.
wire2
Or a car,
Or a lawnmower,
Or a tractor......
:p
No but it's great stuff to seat a big tire to a rim with.
IF you don't mind risking chunks of rubber all over the shop...
