longshanks
Thread starter- Joined
- Jun 12, 2006
- 188
My 1998 2-stroke 60HP Merc doesn't beep when I turn the ignition on.
I tried grounding the tan/blue wire from the wiring harness. With the key on, it gives me a loud beep.
I pulled out the temperature sensor from the water jacket, and confirmed that it appears to be opening when it goes in boiling water. I am guessing that in order to make the motor beep, this little sensor needs to be very hot, and also, grounded to the motor?
So I think I've confirmed that the overheat warning horn will work. Does anybody have any suggestions on what else I might look at, to find out why the beeper doesn't sound at 'power up'?
I am thinking it either has something to do with the low oil sensor, or there is a connection or ground loose somewhere. It is a tiller drive motor, and the horn is located under the handle.
thoughts?
thoughts?
