Water Temp sender in drain plug?
malfar
My sounder has a water temp sensor that mounts on the stern. I hate drilling holes in my transom, so I'm putting the transducer in the bilge. I don't want to drill a hole in the back of the boat for the temp sonsor to to exit nor do I want to drill holes to mount it. Anyone ever drilled out the transom drain pllug and epoxied the sensor in the plug. I think I could do this - however if the sensor ever came out, I guess the bilge pump would be working overtime.
Re: Water Temp sender in drain plug?
drill the hole in the boat, and seal with 3m 4200
180shabah
Agreed, drill the hole. How do you think the manufacturer got the drain plug in there? They drilled a hole.
