WATER PUMP IS IN AND WORKING... but I still have one more question.
gunner1
When I was running the motor in a tank of water, I noticed that the bolt closest to the stern on the right side that holds on the lower unit seems to leak water. Is this normal?
Frank Acampora
Re: WATER PUMP IS IN AND WORKING... but I still have one more question.
Are you sure it is the bolt and not the weep holes? There are several weep holes under the cavitation plate to drain accumulated water out of several blind compartments next to the water pump. Water blowing down with the exhaust may be entering these compartments, draining out and running along the cav plate to the bolt before falling off. Double check.
gunner1
OK, I'll check that out. Thanks.
rudedude
Gunner, I had the same thing. It never had water comming out of the wheep holes before but that was because the little hole in the pump houseing was plugged on the old houseing. Frank did point that out to me. :D
