BassBossAndy
Thread starter- Joined
- Oct 11, 2007
- 12
71' 6hp evinrude fisherman that I can keep in a climate controlled area all winter (my house). do I still have to winterize? sorry i'm a newbie
No need to winterize at all.But you may be rebuilding the carb in the spring.Of course if there is h2o in the gearcase some bearings may rust up,and the motor may seize from lack of lube.
I would winterize it.
DHP
Run stabilizer through it, fog it, and change the lower unit oil after the last use this fall, then store it. It cost alot less to do this then to rebuild or replace something.
hey fire! i thought i'd see/read you in here sooner or later.
