Four stroke vs two stroke
drfish18
What is the best engine a 2 stroke or 4 stroke for a 50-75hp engine?
bgbass.1
Re: Four stroke vs two stroke
iwould take a 2 stroke any time over a 4 stroke the reasons less weight, quicker out of the hole, easier to work on, not as many parts to fail. thats just my opinion
JB
Best for what?
steelespike
Check the BRP site for the 2 stroke Evinrude Etec.Check the testimonials and actual specs.comparisons.Etec makes a 2 cylinder 240 lb 40,50and 60 hp.and a 3 cylinder 320lb 75 and 90 hp.If I was thinking 75 hp I think I would go with the 90 at the same weight.If I was thinking 60-75 hp I'd give the 60 some thought at a relatively light 240lbs.
As far as motor quality 2 and 4 stroke are pretty close.Although keep in mind the service interval for the 4 stroke is higher and more involved than the 2 strokes.Be sure you have a properly trained stocking, servicing dealer.BRP appears to have their dealers up to speed.It is fairly easy to do a srearch on the net to compare various boat/motor combinations.
The Etec has the highest EPA and CARB rating of any outboard also I believe it is the only 2 stroke approved for Lake Tahoe.
rickdb1boat
That's true. You do have to change the oil and filter every 100 hours or so on a 4 stroke. Outside of that, pretty much the same routine as 2 strokes. The Etec promotes no dealer service for 3 years or 300 hours, but I would at least change the lower unit fluid every year. Other than that, the smaller HP Etec engines have done very well with few problems and I wouldn't hesitate to purchase one depending on your application...
