Captain Obvious
Thread starter- Joined
- Nov 24, 2007
- 28
Re: "Grinding" noise from sterndrive
Thanks guys. I'll take your advice and try to disassemble the cable at the throttle and pull the slide and cable out together. If that doesn't work, I'll just cut it.
I got a spanner wrench for the u joint retainer nut and a hinge pin tool today as well. Both are also...... stuck.
Then manual says you can heat the hinge pins to help loosen (the glue I guess), but I had no luck. I am using a standard socket, so I'm looking to get more leverage. I guess 95lbs is more than I had today.
