Re: "Grinding" noise from sterndrive
Well, after 4,219 hits with a 5# slide hammer.... It's out!
I think you guys lead me down the path on this one. Do you
really think the bearing was bad? I probably could have gotten another year out of it.
I noticed I also have some corrosion inside the bell housing (not sure of the term) where the u joint bellows attach on the aft side. Right where my finger is it is corroded enough to make me nervous.
So... Does this mean new bell housing? There is a lip inside that makes it feel like the metal comes out as a piece that can be replaced.
I need to replace the shift shaft seal anyway so I thought I'd ask for opinions before I went shopping.
Thanks
