Ranger 330V
- Joined
- Sep 25, 2007
- 242
1978 140hp Johnson. 100psi compression all the way around. New stator, trigger, powerpacks, rectifier, plugs. Old green coils. She runs great when you "run" her. At idle is the problem...sometimes she does it sometimes she doesn't. There is a bad cough that comes and goes. To the point that it will die. When at first start up its really bad and as the engine gets warmed up its not quite as bad but will start after a time. I'm thinking idles jets because once you start running its fine. The engine sat for 2 1/2 years before I got it. Runs fine other than that. Plugs are nice and light brown...all look the same. I have decarbed also. Could the old green coils cause this?? I'm going to eventually replace them but do not have funds right now. I am also going to rebuild carbs this later when it actually gets cold. Its a pretty good cough...will actually jerk the steering will sometimes. Could it be reeds?? Could I get it idling and spray seafoam in each venturi and see if the stumble goes away or gets better?? That would probably tell me if it was fuel related?? Ask anything else if I missed something in my information. Thanks alot!!
