Vibration / Shuttering
LuckyPenny
I have been having a contiunious problem with shuttering / Vibration. I am running a 21 Foot CC with a Johnson 100HP (1979).<br />Anyway, between 1900 and 2100 RPM the entire boat shutters. Above and below this, she runs fine. Any suggestions? :confused:
alcan
Re: Vibration / Shuttering
Hi Lucky<br />Just some ideas here. Damaged prop, bent propshaft, damaged motor mounts/isolaters, damaged pivot tube bushings,or the tube itself. Check closely for bent/out-of-line damage. You my not have hit anything, but someone my have hit you.
LuckyPenny
Thanks. the only visable damage or irregulatory is scuffing on the leadind edge of the prop. and a very small ding on one of the blades. Would that be the cause? :confused:
alcan
Maybe. Maybe one of the blades is bent more than you think. Take your prop to the prop shop or dealer and have it looked at. Put a dial indecator on the prop shaft and check run out. Things don't have to be completly distorted to cause problem. A little out of ballance here a few thousands bend there. How about the flywheel? Did you take a look see there at all? Loose magnets, cracked flywheel,Etc??
Hooty
I think alcan is on the right track but just for grins, try a prop with 2" less pitch and see what happens. You might be lugging the engine.<br /><br />c/6<br /><br />Hooty
LuckyPenny
If it were the flywheel or loose magnet wouldn't I be getting some heavy vibration at high idle?
crstrode
For what it's worth, I just bought a 1977 Evinrude 85 HP. First time out I thought it was running OK, but with some vibration. I also suspected a bent prop.<br />Lo and behold, after about 20 minutes the fourth cylinder finally kicked in for a few seconds at a time. The boat set me back in the seat withthe extra power, and the vibration went away!<br /><br />(now you know how little I know about outboards!)<br /><br />OK now how do I check the coil from the #3 cylinder without the rest of the motor? No spark from #3, even after swapping plugs.<br /><br />The boat and motor are now 120 miles away, and I was planning on checking the coil, buying a powerpack and new sensor in hopes that one of these high $$ parts will fix it.<br /><br />What resistance should I be seeing on the coil wires?<br /><br />Carl<br />Cheney, WA
