Re: Vibration / Shuttering
For what it's worth, I just bought a 1977 Evinrude 85 HP. First time out I thought it was running OK, but with some vibration. I also suspected a bent prop.<br />Lo and behold, after about 20 minutes the fourth cylinder finally kicked in for a few seconds at a time. The boat set me back in the seat withthe extra power, and the vibration went away!<br /><br />(now you know how little I know about outboards!)<br /><br />OK now how do I check the coil from the #3 cylinder without the rest of the motor? No spark from #3, even after swapping plugs.<br /><br />The boat and motor are now 120 miles away, and I was planning on checking the coil, buying a powerpack and new sensor in hopes that one of these high $$ parts will fix it.<br /><br />What resistance should I be seeing on the coil wires?<br /><br />Carl<br />Cheney, WA
