Re: cracked crank case cover help
hello,
if it was mine, i would stop drill it first [std ops in aviation alum work] and use a COLD SEALER. monitor it for service once done.
and... if it was mine, i would also do my drilling smallest drill bit up to the final size... maybe a 1/16th. and i would run a HD vacuum next to my drill bit so i could catch all the drill shavings. drill slow and shallow low pressure on drill bit. TAKE UR time... especially when about to punch thru. if u can, maybe do final bit twiting by hand... "suck dem shavings!!"
then with the vac running, i would put a V down the crack to give jb or what ever u use [id try jb] maybe 1/8th in V... a nice new home.
then into sides of V i would drill holding holes. very shallow maybe 1/32nd, certainly 1/16th would be ok, imo. then i would work a tool of some kind into the holes to enlarge base. mabe a small spring center punch to upset some. this is to give jb/epoxy addl holding points.
then i would clean area SUPER clean with laquer thinner. and lay in small about of jb. id put tape over cracked area if trying to put jb into a vertical crack. addl jb will bond fine to prev jb application. upset a bit with emory and clean. u can work the jb while still "wet" to keep it up n down in crack. and then when it starts to set, push tape into v. well, u get the idea.
i would do this until i had a nice rounded bead of jb in the worked cracked area. i would do this until it flowed some into the surrounding metal surface for add'l holding looking sorta like a nice beaded heliarc alum bead.
but first i would make some sample runs of jb. a) 50/50 mix. b) 55 jb; 45 catylist. see if a bit less catylist will be stronger when u do a break test. flex them, see if less catylist is stronger. i know too much weakens chemical action in it. but if u just go 50/50 no doubt it will be very strong!!
i have an extensive, indepth working background in using jbWeld on aluminum castings that were modified and reshaped with jbWeld. done as i am suggesting, u will have the strongest bond/repair possible with the jb. my applications were in automotive use. in high temp areas of around 200F... in an fuel/oily environement. in every case, [hundreds using this method, -0- mods failed!!
good luck, and post some pix of ur work for us to see.
u can always go back to heat/TIG, but do a COLD process first. no doubt, it will work just fine...
regards,
lakester
