Re: waterlogged foam
i just now purchesed a 16ft avalon glaspar but i discovered that the foam in the hull is waterlogged i am in need of ways to dry it out, is there anyone who that knows how to fix this?
Ayuh,......... Unfortunately,..... Your Not going to like Either of your Options......
Option #1,.......Sell it,+ Try to get your Money back out of it,......
Option #2,....... Seperate the Inner hull, from the Outer hull,..... Dig out All of the saturated Foam,..... Then figure out just
How you can refill the area with New Foam.........
Due to the Work involved,+ the Impossibility of getting the Foam back into place,.........
Option #2 Really Isn't an option At All,.. in My book.........
Soooo,........
I see Option #1 as the Only answer to your Question,..........
'cause as noted by Chris,........It'll Never, Ever, Dry Out..............
Btw,............
Welcome Aboard to the forums here at iboats.com,.................
Home of the Truth,....... Good,... Bad,... Or Otherwise......................
