cbear34
- Joined
- Jul 7, 2007
- 144
Question is about a 1989 maxum 2000sr, merc 305/230hp, alpha one drive.
Last time out last season my boat overheated on high rpms. Figured it was a bad impeller as it has not been replaced in a long time. I finally got around to removing my lower unit. The impeller looks fine but I found a completely melted piece in the lower unit. I think it is the water tube. It looks like it might be made of hard plastic and has a tube like look at one side. The other end is completely melted. Also the rubber centrifugal slinger is cracking like it was overheated, probably. Could this cause an overheating problem at high speeds?
Also the waterpump gaskets are hard and came off in split pieces. I checked the lower unit for corrosion at the pump and gaskets and that looks fine.
Thanks for all the help!
