oops!
Thread starter- Joined
- Oct 18, 2007
- 12,932
Re: hull extension in progress with picks
well murphy showed up big time yesterday......
first of all....i was so tired from the marathon the day before....when i got up in th morning....i sat on the puter here at i boats tring to wake up for two hours instead of working on the boat......
i got to the boat at around 8 30 ish and started to finish the fairing....just little touch ups......
i had posted earlyer of small pinhead like spots on the hull that were appearing everywhere.......i finally figgured out it was a wax build up on the sand paper....as i sanded the poly fair...it created a wax biuld up on the paper ...it would then stick to the hull when the sand paped got hot enough....every little speck of that had to be removed.....
at noon...i had about 15 minits of work to do on the boat....but it was time to get the compressor and the gun...so i left.
i called my bud who was supplying the gun and he was late organizing the gun...so it wasnt ready.....i whipped over and grabed the compressor and some supplies i needed...(aceitone...a squeegee and more of those little measureing pails from rona.....there perfect for mixing...they have all the measurements on the side......
at 2 pm....the gun still wasnt ready so i ran to the shop in super heavy traffic to find the gellcoat guy had been and gone......
those were the white footie prints in tackelwashers first pic.
mike the gellcoat guy had left and gone to the shop where the gun was....i called him and finally he was able to pick it up...and get some more gellcoat
when he got back to the shop....i was finished the hull....and sweeping the dust from the floor...we assembled the gun....and found that the air hose fittings were not compatible....so i grabbed the part....back to the rental shop and swaped them out.......i also took the gellcoat to a paint store and had them shake both 5 gal cans of gell......(more on that in a bit).
after i got back......we tested the compressor ....and it was faulty....not enough pressure......load it up and get back to the rental shop.....after some putzing around....they gave me a super big compressor....so it was back to the shop....by then tackel washer was there....my das was pulling in and my local resin supplier was also there....a whole crew!
this is my local glass rep....prepping a can of gellcoat
we started to assmeble everything and get ready for mixing the gellcoat
its imperitive that every thing is ready....when you start the process....there is no stopping for a break....it is go till its done....then clean the stuff before it gells....its quite a process.
in pro boat shops....gellcoat is applied thru a special gun....this gun sprays gellcoat thru one section and another adds the catylest each componet can be individually adjusted.......
when you dont have that set up....you alpply the gell with a "hot pot"
in this pic....you can see the pot that is attached via hose to the gun
hot potting is a simple process where you mix the resin and the gellcoat seperately with some aceitone (the aceitone is used as a thinner so it can go thru the gun easyer) when you are just about to spray...you mix in the catylist...and pour it into the pot......hence the name "hot pot".....once the cat is added the clock is ticking.....if you dont spray it in time...the catylist will make the gellcoat harden in the gun and the pot......if that happens....you scrap the gun...lines...and start all over.
