hull extension in progress with pics
Status
Not open for further replies.
Renny_D
Re: hull extension in progress with picks
-- double post --
Renny_D
...it would still need to be marine-ized, though.
and converting the cam to a marine one might lose you some of that HP, just FYI.
Hi please help a boating newb. Why would the cam need to be changed to make it marine unless you,re talking about having one of the engines turn in the opposite direction - refering to the two bbc that they were offering. I can see other things like alternators and anything else designed to keep one from blowing up by why cams? There must be a good reason that I'm not seeing/understanding.
On the hp/engine decision. I am still learning boats but I've played with cars for years and for years I've played with BBC but lately I'm discovering the joys of small displacement turbo charged engines. They are definitely the replacement for displacement. I'm currently running low 13's in a 3600lb car with only 2.4 liters - should actually be in the 12s but the season ended before the latest iteration of my car was ready. A 350 with good heads and fuel injected running a moderately sized turbo will make 600 ft lbs all day long and have full boost by 2200 to 2300 rpm with the right cam. Plus it will make that kind of torque by 3500 rpm and carry that to 6000 easy. I've got a good friend with a 3 liter v6 that is making 504 ft lbs of torque and 500+ hp and with a nice 5k rpm band of torque available. Turbos will give you the best of both worlds, high torque, broader power-band and good fuel economy (because the displacement isn't there when your throttle is not mashed. ) The other side benefit is they are quieter..
My .02
Renny
fixb52s
If you want reliability and hp look no further than the small block chevy 350. Bore it .60 over and you're an instant 383......
Want more, supercharge it, (no whine and instant on).
It takes more than a .60 overbore to make a 383. The bored out 350 will only produce 355. What makes a 383 is a stroker crankshaft out of a 400. Then some machine work is required for the rods to clear the block. Not as easy as it sounds, but not real hard either. 383 stroker engines are produced in crate form though.
As for a supercharger, I never seen one that doesn't whine.​
oops!
renny....
the marine cam is different.....uasually called a rv or marine cam.....the duration and lift is different.
boats are made to run at WOT (Wide Open Throttle) for extended periods of time, so a standard cam wont do.
as well.....boat motors are allways under load. a car can coast at a said speed. boats cant. as a result......the cam must be different.
oops!
bubba .....what does every one do an fri and sat nights there ....go to the track? :eek::D
erikgreen
Good response Oops... one other thing about the cam for you car folks out there, or those used to using "hot" cams for more horsepower.
In a marine inboard engine, you cannot overlap intake and exhaust valve timing. This is because an engine, being among other things a big pump, will cheerfully suck in anything in its exhaust system if the exhaust valves happen to be open on the down stroke of a piston.
In a boat, what's in the exhaust system past a certain point can include water. It's not really near the cylinders, but it's in there, and the engine can suck it up if the cam is too aggressive.
Water being incompressible, this will probably cause a major engine failure, possibly anything from blown heads to grenaded pistons to a cracked block.
I have an aggressive marine cam in my 350, it's roughly equal to a corvette stock cam... going more aggressive than that would probably be foolish, and it's of limited value anyway in a boat since boats benefit from higher torque far more than HP... as someone put it, "there is no replacement for displacement".
By the way, most of what I know about boat engines has come from the guys on the I/O and inboard section of iboats, Don S. in particular.
Erik
Renny_D
Erik
Thanks that makes sense - Oops' original response confused me as road race cars I play with are often under full load until braking. I still say turbos are the replacement for displacement however. With the right bottom end you can more than double the horsepower yet when off boost have a nice sedate motor. Hotrodders in europe are getting +300 hp/liter and that is not the crazy f1 big money guys but guys in their garage on weekends. That would be the like make 1500 hp from a 302. Tell me how you do that with displacement. Also a marine cam, as you described it, would work really well with a turbo especially if you are trying to make power at lower rpms and carry that torque through to redline. Low rpm turbo power is all about small turbine sections for fast spool as they begin limiting themselves due to excess exhaust manifold pressure ratios very early. Again I say the best of both worlds - hp when you want it and good gas mileage smooth running when you want to putt around. Having played on both sides of the displacement game I prefer forced induction or as my friend said "If your motor doesn't have forced induction then it 'sucks' ;)
Thanks for letting me rant. Either way can't wait to see this thing moving.
Renny
GO OVRIT
I believe one of Oops' reasoning for starting this whole project was to avoid having to swim back to the dock pulling the boat. Seeing as how Murphy likes to check in on this project as much as the rest of us, I would think "simple" and "reliable" power would be good. I play with a lot of turbos and with fuel injection (mechanical and computer controled). What I've found is that there is only a given # of horspower/hours per cubic inch. You can get them out in big #s for a short period of time or in smaller #s for longer periods of time. Forced induction is good power, but at the cost of a lot more cylinder pressure putting faster wear on the bottom end and the head gasket. Not to mention water cooled turbo choices are more limited making it harder to achieve an ideal delta p. A big displacement mildly built engine that doesn't have to work as hard will definatly last longer and have a smoother powerband. Personly I prefer a carb. 7 psi max fuel pressure, no electronics to get wet and corroded, no need for a return line, etc.... Thats my couple of cents for you.
oops!
so for the sake of continuing this utterly fantastic discussion,,,
how would a person turbo a marine motor?
and where or what choices would be there for cooling?
i know closed cooling is popular in salt water.....i had a system once, but the exchanger leaked....so it just caused me trouble.
colobiker
I am having a PM conversation with Renny about that. (as not to highjack your thread)... near as I can tell.. if the enging had an automotive cousin that had a turbo.. you might be able to do it pretty easily.. if not.. it would be some fabrication. .. I am totally into this.. i can see flipping the cover off of my boat and showing off a gleaming turbo..
Renny is the man.. he has done turbos before.. but I dont know if he as done it to a boat or not.. i am totally facinated by this topic..
erikgreen
The only way to turbo a marine motor is to have it custom built... as far as I know there are no stock turbocharged marine motors. Mostly this is because a turbocharger works off of the engine's exhaust pressure... in cars the exhaust is used to turn an impeller that drives more fuel/air mix into the engine.
This is fine for cars, but on a boat it's more complicated because you usually have wet exhaust, so you have to run the exhaust through the turbo then out through whatever the rest of your exhaust system is, EG wet manifolds or through-hulls (with mufflers if you're anywhere that needs them). The simplest system would be to assume a dry exhaust like a through-hull system. But then you have to have a "special" turbo... the turbocharger is powered off of engine exhaust, so it gets really hot. Not a huge problem for cars since it's under the hood, but in a boat the temp is a fire hazard, and it exceeds the coast guard's temp limits for inboard boat engine parts. So a turbocharged boat won't be USCG certified, and may be hard to insure, unless it's listed as a race boat, which is another can of worms.
Well, your point of view is similar to a lot of car type folks I've seen that are new to the boat world. It's apples and oranges though.. here's why:
A turbocharger can be designed to provide a low end boost to a point, but it's only a fraction of its rating, IE 1% addl HP or so. Look at a dyno graph of a turbocharged engine vs an identical non turbo engine and note where the power is mostly provided... power increases exponentially as RPM increases, because the engine is providing more pressure (in the exhaust) to turn the turbo. This is limited by materials, exhaust pressure, and the max turbo RPM of course.
Turbos run off of exhaust gas, and at low RPM there just isn't enough exhaust pressure to provide a noticeable boost.. in a turbo powered car there's usually an engine RPM where the "turbo boost" kicks in. If you're not ready for it in some cars it may even cause a safety issue since you suddenly get a kick in the pants.
In a car, you use a transmission to absorb your engine's power and transfer it to the wheels at a useful RPM.. for instance redlining the engine at 9000 RPM in top gear you're usually converting the 9000 down to 1300 or so, since you can't really turn the tires at 9000 RPM... part of that conversion is in the transmission, part of it is in the differential. So gaining power by increasing RPM is useful... you can live with lower torque if your RPM increases because your transmission can convert the RPM into torque at high RPM, and you can downshift to get moving quickly at low RPM.
Additionally, tires can run efficiently at a large range of speeds... unless they're slicks, or running in wet/icy conditions, pretty much one rev of the tires moves the car one tire circumference.
On a boat, it's really a different system. I'll use an I/O as an example since that's what I know best.
The engine runs at its factory RPM usually.... for a chevy small block that means WOT is about 4200-4600. It doesn't make much sense to go higher for several reasons related to power (see below) but another major reason is the usage graph... if you graph a car's engine RPM over time, the graph will show spikes as you shift, speed up, etc. A boat's engine typically is revved to a certain RPM and left there... for hours at a time. Imagine how long your hopped up car engine would last if you got in the car, started the engine, left your driveway, then floored it and held it down for 6 hours? Boat engines do that all the time.
The engine output runs into a sterndrive via a rotary coupler. The sterndrive is basically a pair of right angle gear transitions that move the rotating output power down about three feet and reduce RPM by between 2:1 and 1:1 or so. Only one gear ratio is available, although you can shift forward/reverse and neutral. It's not built with more gears for reasons related to the prop (below), but another reason is the use curve again. In the above example driving your car, which component would die first, your transmission running redline all the time or your engine?
So the power goes engine->sterndrive->prop. Here's the real difference between boats and cars (like you didn't know, right?). The prop isn't friction based, it's a reaction drive. The blades shove water backward, and the boat goes forward.
Due to the physics of propellers (they're simple machines, basically archimedes' screw) they have exactly ONE speed and a small range of RPMs they work most efficiently at. Speeds (defined as forward movement through static, non churned water) below that limit they still work, but rather poorly. Speeds above that they still work, but deliver no extra thrust no matter how much faster they turn. RPMs below that range still work, just poorly, and RPMs above that range don't work at all (see below).
The no extra thrust at high forward speed is a limit imposed by the prop pitch.. basically the prop (and boat) are moving through the water too fast for the angle of the prop blade to get "ahead" of the water flow and push backward... if the prop isn't able to shove water backward faster than the flow around it, it's effectively standing still (think about it). Increasing the angle the blades grab water ahead of them at increases the prop's pitch.
Why the RPM limit? Water isn't solid. It cavitates, IE transitions to vapor under enough pressure. Also, a boat floats on the water's surface, so the prop is always near the surface. Boats can push air under themselves and into the prop sometimes, or the trim mechanism can move the prop out of the water. If the prop is not designed to pierce the surface (some are in fancy Arneson drives) then this is called "ventilation"... it means there's bubbles of vapor or air around the prop that are affecting thrust. The prop on a boat doesn't push air very well, and it provides not much push with bubbles. Higher RPMs have the potential to create more bubbles faster, up to the point where you're pushing almost no water, just creating bubbles.
So in addition to one forward speed where any given prop works best, there is pretty much a small RPM window where it works at all. Below that window its thrust backwards doesn't exceed the turbulence created by the blades (imagine a prop turning in neutral) and above that RPM it starts to ventilate and thrust drops.
So then... the gears in the sterndrive lower the engine RPM at WOT from 4200 or so down to (in my V8) about 2800 RPM maximum or so. That's a good range for my 14.5" prop to spin at... not too much ventilation. I can still adjust prop pitch by replacing props, which changes how much water gets shoved backward with each prop rotation, and sets my max speed. I can't go above a certain pitch limit though, because the engine has to have enough torque to overcome the resistance of the water to the pitch I choose. Resistance goes up as pitch goes up (to go faster you need a higher pitch prop, to use a higher pitch prop you need more TORQUE!).
Now there are a couple other things to consider here. First, boats need a good amount of thrust at low RPM to get on plane... this is another difference between cars and boats. Cars have a linear required power curve from 0 to wherever drag starts to have a significant effect. You can speed up to 20 or whatever, more with the wind, using a certain amount of torque (once inertia is overcome) to get moving, then add RPM to go faster. Hence the multiple gears in a car transmission.
A planing boat must first push itself OUT of the water, so most of its hull is in air, in order to go faster than a "displacement" hull whose speed is governed simply by its length. A displacement hull does not go faster than its design length period, no matter how much power you add. So to go fast we need to get our hull out of the water. This reduces friction from the hull and we speed up.
That takes a lot of thrust.
So we throw power at it... we go WOT to turn the prop at the top end of the RPM it'll make power at (remember it works better and better until it reaches optimum RPM and forward speed) and hold at WOT until we're on plane, at which point the decreasing drag and increasing forward speed causes us to speed up a LOT (faster speed means the prop works better, which means more thrust, which means faster speed...), and we cut throttle back to hold the speed we want on plane.
We could just use a lower pitched prop, that works better at low forward speed, to get on plane quicker, right? But you need a high pitch prop to go fast! So it's a trade off... high top speed vs. good "hole shot" or getting on plane in the first place.
With me so far? Take a break, get some coffee, I'm not done yet :)
So what happens when we add a turbocharger? Well, it adds HP (which is a measure of work done over time) by adding RPM, which is part of the HP equation (it's actually HP=(torque(lb/ft)*RPM)/5252). If you look at the equation, it makes sense that you can increase HP by increasing RPM (how fast the motor spins) or by increasing torque (how hard it tries to spin).
So engine ratings in HP are deceptive... two engines with equal HP may have wildly different torque ratings.
Setting aside the engineering problem of installing one and keeping it cool in a boat, a turbocharger adds power by adding RPM. Which it does very well above a certain minimum RPM level.
If we add a turbocharger to my V8 boat, what will happen is that when I reach a certain RPM, the power curve changes... smaller increments in throttle produce large RPM gains (at the expense of fuel use, of course). So what do I do with that RPM gain?
Nothing.
If I go above the prop's RPM limit, I'll get cavitation. So I have to move the throttle lever smaller amounts as I throttle up to get the same RPM. I could get the same effect by changing my hand throttle to require less lever movement for the same throttle setting.
Could I change the drive unit gears out for a different ratio? Sure! If I put gears in with a 3:1 ratio, or double what the V8 used, then I can keep my prop in its RPM range! But unless I change to a higher pitch prop, I can't go any faster through the water. So I'll have to do that.
But will I go faster than the non turbocharged boat with the same prop? No. As long as the non turbo boat motor has enough torque to spin the prop up to optimum RPM and maintain that RPM until we reach optimum forward speed, then the extra torque we get from the turbo + gear reduction does us no good.
Remember that we need only enough torque to overcome water resistance on a given pitch prop. As long as we have a minimum, we're able to spin that prop up to full speed. The turbocharger + gearing do add some torque to the prop over the non-turbo engine, but since our engine torque curve falls off at higher RPMs, it's a diminishing return as we increase RPM (the RPMs have to go faster and faster to maintain the same torque level).
A big block, on the other hand, has a flatter torque curve through the RPM range the prop is using because it's not using high RPM + gearing to make high power.
So we increase prop pitch to increase our boat speed, provided we don't move pitch too high to have a successful hole shot, and provided our engine can still turn the prop to full RPM we'll keep going faster.
Forever? No. Every hull has a maximum speed on plane. Without hydrofoils you can't get the whole hull out of the water. Even with a big engine, it's possible to have a high pitch prop you still can't get to full speed if you can't get your hull high enough out of the water.
Can we lower the amount of thrust needed to get our hole shot? Sure! You cut weight of the boat itself, you bring less people and gear, and less fuel, and you shape the hull to direct the water downward as much as possible, instead of pushing it sideways. A perfectly flat bottom will require much less power to plane than a V hull. Additionally, the less hull we can have in the water, the less drag there is on plane, and the faster we go for a given amount of thrust.
So the quickest boat to plane is a flat bottom, and the fastest boat on plane is one with very little hull in the water. Ever look at a hydroplane race boat? What if we found a way to remove the sterndrive lower unit from the water, so the drag from that goes away, and at the same time we changed from a propeller drive to something that works in air instead? We could really scream. Ever look at a hydrofoil?
So in exchange for our large $$$ investment in a boat-converted turbo and custom drive with custom gear ratio plus more expensive insurance, we got exactly the same return in speed as we did for just buying a new prop.
To get the best speed out of any boat you need to pick a prop that will push the hull to its max speed (usually the hull shape and weight decide this) and then pick a sterndrive (gear) and engine (torque/RPM) combo that has the minimum torque to swing that prop and generate enough thrust to get on plane. Once on plane you can accelerate to the top speed the prop can handle.
On 383s....a 383 stroker adds torque over a 350, just like a big block does. Typically they run at higher RPMs than a 350, which isn't too useful, but the torque helps. However, a 454 or bigger will have more torque than the 383 by a lot, assuming equal engine generations. The 454 will run cooler and last longer, and it can produce the same speed as a 383 with cheaper gas because it has a lower compression ratio.
One more thing to keep in mind when deciding on boat engines.... the drag curve in the water is (I believe) exponential, and the curve gets very steep above about 55-60 mph. In a car, modding the engine for an extra 20 HP makes a big difference in top speed. In a boat that already goes 60, that extra 20 hp might let you make 62 miles an hour. It doesn't matter how you add the power. So to go from 60mph to 90mph in a boat, assuming your hull can do that, you might need to triple your horsepower, preferably by providing more torque. One way to do that is by tripling your number of engines of course...
There's no replacement for displacement in a boat :)
Erik
MERIT6419
Man Erik All I Can Say Is Wow
58hydraglide
Erik,
You just made all that up didn't ya!:D:D
(well, you DID answer a few questions that lingered in the back of my mind!)
someone needs to put a stickie on that post.
Renny_D
I have to believe that there have been turbo small blocks before this discussion but for the sake of it let's say we are blazing a new path. Single turbos are more efficient and holsets hy35 or HE341 off of the 6.2 liter cummings can be had for really reasonable prices and since they are oil only turbos you'd just have to fab a return at the top of the pan and t off of the oil pressure sender for the feed. Turbos don't need a huge oil supply just a consistent and clean one.
For ease of building I would use a set of flipped automotive manifolds so that they are pointing forward and up then build a the plumbing to the turbo off of that. Easiest from there would be a single downpipe (I guess maybe and uppipe for marine) going straight out and overboard. Otherwised I'd then ypipe that into two bigblock remote mixers then overboard. I would not run it through the prop as turbos hate any back pressure after the turbine.
A better bet would be a set of port matched headers to a single turbo because you could then go a to a larger turbo - get better mileage, top end and still not loose any spool. A holset HX35 or HX40 or a To4 based garret could be run.
If you are only playing with fresh water then having a raw water cooling system would be fine though a closed system would be better as the temps are more consistent. Also if you plumb it right then it's would be pretty easy to swap to a raw water system in the case of an emergency. I've done this on sailboats several times when I've eaten a raw water impeller.
Then after that you need to either have a carb(s) that have internally vented float bowls or build a box around the whole carb(s).
Add a air to water intercooler - you can plumb this right into the current cooling system intake but it should have a seperate pump so it's not taking heated water off the waterpump - waterpumps push hot not cold water..
Lastly you want a way to retard timing. If you vacuum advance dist. has enough movement then you could just run that and it will retard with boost. There are also plenty of electronic boost retard options MSD makes a nice sealed marine version that also includes a revlimiter and a hotter spark ta boot.
that's like a 10,000 foot view but there would be tons of small details to solve but it's not like you haven't been a vanguard before.. :)
thanks
Renny
Renny_D
Hi Eric, thanks again for your post and I will respond but I'm off to dinner then moving my companys office. I will say some of what you point out is true but one huge error is that turbos require high rpms to make horsepower and that turbos make peaky torque curves neither of which is true. Some things to chew on - volvo makes turbo diesel marine engines - what rpm do those turn at. Also at the top of the technology curve in the automovite world these days is high mileage turbos - little engines with very flat torque curves in fact flatter than any na big v8 that I have ever seen and with torque that is available instantly.
More later ... thanks
Renny
fishrdan
I was elbow deep into one of those years ago helping the owner replace an impeller. Don't know much about it other than it was turbo and supercharged,,, as so the owner explained. Superchaged for low RPM's and then at a certain load or RPM it would cut over to the turbo.
If you are going to use forced induction on a boat I'd think a supercharger would be a better solution, better low end and you won't have to fool around with the exhaust.
redfury
I think a Paxton Supercharger would just be easier, though you are not going to get the mileage that you would with a turbo set up.
erikgreen
Renny
A turbo diesel is a very, very different engine. It's not just apples and oranges, that's comparing an apple to a string bean. The largest similarity between a turbo diesel and a gas diesel is the name. The turbo diesels operate with high pressure fuel rails, spread detonation of fuel, and a host of other nice improvements over the naturally aspirated diesels of the past.
A diesel provides a much better torque curve than a gas engine, so the marine ones are great for boats. So yeah, a turbo diesel would be a great choice provided it's big enough. The down side is of course the price... a turbo diesel engine in a 320 HP stern drive version would run about $25k. Compared to about $5k-$7k for the big block gas engine.
I'll re-quote here for a more specific answer to something:
I didn't say they make "peaky" torque curves. They make a power curve based on the initial engine curve (like any engine add-on) with additional HP provided by increasing RPM via forced induction. Since they use exhaust gas to drive the turbine most of the power is added in the latter half of the curve, coincidentally where the engine's factory torque starts dropping off.
In combination with the theoretical gear ratio I talked about the additional RPM would be transformed into more torque, and the theoretical resulting torque curve (at the prop) would be similar to but weaker than a big block torque curve up until the drop off around 4500-5000 RPM. Since our hypothetical engine/drive combo needs to make up to 8400 RPM to achieve optimum speed for a high pitch (fast) prop, you're taking quite a bite out of the curve when you use the turbo to get those RPMs.
If you want to interpret the resulting composite curve as "peaky" that's up to you :)
Sure, a turbo with electric assist can provide forced induction at low RPMs. But the result is still more RPM, not more torque. Forcing more air in with a supercharger is a bit better, since the forced induction at lower rpms can help flatten the torque curve (forced pressure at low RPM can burn fuel better).
Neither one changes the moment arm of the pistons vs. the crankshaft, although you can change the pistons and heads to increase compression and therefore add torque, the additional compression usually means different (more expensive) fuels to avoid pre-detonation and other problems.
For Oops' boat, he needs more torque to swing a bigger prop, to get that extended hull out of the water. Adding a bunch of RPM doesn't do him any good.
So far I'm recommending a big block engine for him. It'll run cool and be reliable on stock fuel (87 octane), provide plenty of torque at the right RPM to run a B3 or Volvo DP drive, and it costs less than a shiny new turbo diesel or probably a fully modified 383 stroker. He can buy new or a reman big block and use stock Mercruiser parts.
It doesn't have the "cool factor" of a shiny hot rod tricked out custom built engine, true, but he can always buy that marine turbo diesel later.
Erik
PS:See my above post for a note on hull speed... it's entirely possible that the difference in speed for this boat between a stock 350, a 383 stroker, and a 454 might be as small as a few MPH. It's all going to depend on the drag curve of Oops' hull. That's why installing the 4.3 he's got now is a win... that'll give us some idea of the engine he needs for the performance he wants.
erikgreen
One more item - the high mileage turbos Renny mentioned.
Yup, that works... for cars. Shrink the engine down to a 1 or 1.5 litre, and boost RPM on the high end with the turbo. Use a suitable transmission to deliver torque on the low end via reduction gearing, add in fuel injection for quick throttle response and computer control, and you have an engine that will sip fuel most of the time because it's a small displacement, but will still deliver HP via high RPMs when you want to go fast.
No argument for cars, but car != boat.
One more thing... I'm sure you guys have heard of Verado outboards, right? These are supercharged Mercury engines. Nice units, rather high cost at the moment though.
As far as I know they use an engine design with a custom supercharger built into a relatively low displacement engine block to provide forced induction at any RPM, with gearing in the lower to turn the RPMs into torque at the prop shaft and run a prop at the optimal RPM. Basically, this is using a supercharger to provide the same power as a big naturally aspirated engine but in a smaller, lighter package.
If you want to go faster than the max high pitch prop Mercury supplies though, the solution used on Verado powered boats is....... more Verados :)
I saw one at the boat show last year with 3x 300 HP engines...just the engines alone ran nearly $100k...
Erik
oops!
im so glad this discussion is on this thread so it wont get lost in the archives some where....man this is really fantastic stuff....
erik.....thanks for the work....ill have to read this a few dozen more times.
renny...looking forward to the discussion.....
ill be adding this to the index.
and btw erik....are you a regular at the holiday in experss? ;)
Status
