hull extension in progress with pics
Status
Not open for further replies.
salty87
Re: hull extension in progress with picks
I have never used, been on, or even seen a boat in action with a tower, but I have to ask. Is there any concern with having the tower too far forward? Would a skier be able to pull the forward end of the boat to one side when carving? Probably not but I just thought I would ask.
maybe on a jon boat. actually, on most smaller boats you can feel the rider yanking on the boat...tower or not. the tower doesn't actually change any of that. the boat still weighs near 3k lbs or more....200lb rider isn't gonna do much no matter where the rope is tied.
wakeboarding and competition inboards have tracking fins to help counter the pull of a rider cutting out hard.
eight tracker
Back a couple hundred posts someone mentioned that oops was going to extend the windshield height,that would balance out the boat to the tower a lot better so the lines will flow.
My two cents. tom
NoKlu
It's a real problem trying to find the right extrusions to do anything to the windshield right now but the search is ongoing.
MERIT6419
oops Its really coming along. I thought I remember a couple months back you were tossing around the idea of a curved windshield did that get nixed? hope you found a flywheel. You know its not to late to take that 350 and stroke it out to a 383 then you could put a supercharger on it and a nitrous system then you could say it is stroked blown and juiced. lol
oops!
OK I just found this tread today around 1:00AM and I just couldn't stop reading it now its 5:58AM, and finally got to the end. I most say this is one of the most educational readings I have ever come across regarding fiberglass, molding, etc. The boat really looks fantastic.
I was thinking you should consider writing a book with all of the material you have posted in here.
I will continue reading on your progress.
Congratulation
Rick Nieves
hi....welcome aboard !....to the extension chaos.....and iboats....lol.
i really hope this thread will help people.....with all the discussions on every aspect of boat building i think this is the most all around discussion on boat building in this forum.
not only that.....but the people that post here ( at i boats) are becoming a real family.....its really cool !
ok....update time !.
oops!
ok....sorry i dont have time to post pics.....i have had family in town and have been doing the tourist thing.....
yesterday we rode bicycles from some old train tressels all the way to pentiction....over 80 k on a bumpy gravel and sand rail road path......took 11 hrs. 6 hrs up hill in deep sand and one hour break at the top, and 4 hours down. my butt is so sore i can hardly sit....lol.....i think im damaged for life....:eek:
ok....the boat....the transom is cut out .....it is correct for thickness, parellellism and flatness......
for those of you that dont know what that is.....let me give you some quick definitions and explanations....
first.....the hole it self must be exactly in the right spot.
the hole must be cut so that the anti ventelation plate is exactally in line with the keel....or speed/handeling problems will occure.
the hole also cannot be on an angle....as the drive will be tilted either port or starboard.....habdeling problems will occure.
flatness.....the outer and inner surfaces of the transom must be flat...the tollerances for this are in millimeteres....the have to be flat or the boat will leak and your transom will rot!
thickness......the transom must be the exact thickness of 2 inches...this is how much you need for the drive shaft to bolt into the housing and the bolts to go thru.
parelellism....the 2 inchse must be paralell all the way around the area to bolt the two inner and outer plates togeather with out leaks.
now.....my transom was too thick....it was faired from the out side with different thicknesses of fairing compound and on the inside i had different layers of glass!.
frist i cut the hole.....then using a router set to 2 inches....i routered out the inner side of the transom.....
then using a grinder...i ground down the inner part of the hole to the 2 inch thickness....
i used a laminate gauge for the 2 inch thickness.
parelellism was a real pain.....i again used a grinder to grind out the area around the inner plate till it was flat and even....i used the inner plate as a guide for this.
in mechanic school for boat mechanics.....they give you a week to do this on a transom surface that is allready flat and parelell, at 2 inches thick.
i did mine in less than a few hours total working time.
im just about to run to the shop and glass the area with a thin layer of csm for waterproofing the exposed transom wood on the inside....
ill add pics to this post as soon as i have more time....
cheers
oops
redfury
Well, that right there tells me that I'm sticking with an outboard...too much to dicker with for me...my ADD would have me cranking bolts down and squeezing sillycone in there till it stopped leaking :eek::D
Billiy
Opps you Rock i just found this forum well i was looking to see if about patching a nicks in the gel on my bliner and seeing if there was any thing speichel i nned to know about glassing in a added battery box under the front bow seat. started reading your thead 3 days ago just made it to the end between RL stuff
Darren Nemeth
Oops, please post a video on youtube of your maden voyage.
jonesg
hey check out this guys reno conversion,, I got a load of inspiration and ideas from this guy.
Almost makes me want to tear my boat apart again...almost. Let it load and run the slideshow.
He posts on the classicseacraft.com website.
I think you'll get some different ideas for your fit and finish.
http://s728.photobucket.com/albums/ww290/88bowtie/?albumview=slideshow
72SideWinderSS
Been Five days, any thing happening lately?
Been followin along since the "Should I do It" Thread.
My Hats off to ya oops, good job.
VV Cephei
Like many others, I came across this thread through a search, and I read the whole thing. I've read it on and off for the last week, and I must say there is a lot of great information as well as inspiration here.
Great job oops, it looks light the light at the end of the tunnel is getting close.
I recently designed and made a small 10' flat bottomed boat, and I sort of laugh to myself when I first thought of it as a big project after seeing what you've undertaken here! Again, excellent work, and I'm looking forward to seeing and hearing about your continued progress.
captkevin
Have a question regarding the very 1st pictures of your boat has a Traveler logo on the side close to the end. Many years ago my family owned a 1967 Traveler - Neptune model & looking at old pics the logos are the same. Just curious as to why your Searay had these on them?
fishon13
hope all is well opps,
I'm looking forward to seeing your next update hows the flywheel search going? BTW the tower looks great in the forward position, but looks like the rope might get in the way
Yar.
Hey Oops,
What is going on down there?
I am going to have to come down and see what is going on:p.
We were out on the big lake today for hours and it was absolutely perfect. Usually in the afternoon it starts to kick up but today it was like glass here. We left the teenagers at the beach and went for a mommy and me ride for 4 hours!! So good for the soul!
Anyway, hope is all ok and I will be dropping in soon with a couple of pops to discuss progress:D.
Cheers,
Yar.
Cptkid570
Ensign
Oops, how are we supposed to get motivation for our projects without having updates from you! You are the driving force for us all.
Are you spending all your free time playing on y our bayliner?
Gambrinus
I have been following this thread for quite a while now. I just wanted to say Thanks!
I decided to buy a boat that had a ?soft? spot in the floor, knowing I would be removing and replacing the floor, Stringers and possibly the transom. :eek:
I would not have bought this boat if I had not had this discussion (and others within iboats) to refer to. This boat repair was a project for my son and I.
We have just closed in the floor and we are now doing the painting.
I would like to thank all of you who participate in the discussions! It has been a great help and inspiration for this project and I am sure there are many others that are in the same boat.
Once again THANKS!:p
Gambrinus
NoKlu
Server to slow, lots going on in boat werx,I'll pester oops! for an update soon. Gambrinus, you read oops! thread and you went out and bought a boat with a soft floor? Kinda sick don't ya think? hahaha:D At least your in the right place for that kinda stuff,most of the guys in this forum have the same affliction and some get it more than once. You won't find the cure here but you will get the support you need to get you through the tuff times. Welcome to iboats.;)
Status
