Re: hull extension in progress with picks
lol..... ill get pics up asap......i got tons......we are about a month behind in the pic updates......
so ill catch us up quick.....id do some now....but i got a alpha drive to sell tomm morning.....
well.......had a lousy day on the boat today.......with a minor milestone reached...
i was concentrating on the various parts of the motor and getting them painted and put on.......starter, alt, ect.....ect.......btw.....the block is now black and hanging on the crane.
i installed the transom assembly tonight ans mucked up
the transom bell and housing (the outer part of an i/o housing) was sitting around and waiting to be installed........when i got tired of prepping other parts for install, i decided to mount the bell and inner transom plate (thats the outer gymball housing and the inner plate that the steering mounts to)..
well long ago i glassed in the cutout area.....i decided to add some 4200 to the area just for good measure....
after doing that i added the seal to the bell housing......but the seal had a weird twist in it.....(this was mercrusier parts) i could not get the seal....(a thick foam gasket) to lay flat in the groove of the housing ridge.......after many an effort of 4200, gasket tack......i decided to contact cement the gasket in place........it finally worked.
when the outer bell was installed, i placed the inner frame.
thru the frame was the trim hoses, the shift cable and 2 aets of wires.
we;; after it was all in place and secure i noticed, that the 2 sets of wires were pinched.......they had a special hole to go thru and i pot them in the wrong hole !
so.....to make a long story short..... i jury rigged a line fro m the bow hook to the outer bell (because i didnt want to disturb the gasket glue on the outer bell).......and released the pressure of the bolts on the inner frame.
i was just about to fix the wires when i realized i didnt have any solder to fix the wires.....so i just left it till tommorow morning,,,,,,,,,
so.....it was a day/night of minor accolimplishments and major trimphs but also another step backwards.......
bit it is getting closer to the launch.....
cheers
oops
