Re: 89 30hp missfire after 10min warm up
3 wires??? should be two wires for the A/C from stator, most likely yellow, input to rectifier, output of rectifier probaly red, make sure you have it connected as a bridge rectifier, anode to cathode of doide, one gives neg dc this goes to ground, forward biased diode gives off positive dc, should take 4 diodes, unless you are only making a half wave rectifier in that case, 2 diodes would work, seems like you would need a full wave to get the "charge" effect, any waty as long as it is working good deal.
Just got back from the maiden voyage, 17' skeeter starfire with a 1973 85hp rude, old engine did great, specks were hungay also
