survey.. how long to finish
joy
Okay, being green to Iboats and enjoying all the wealth of info. Here's my question. How long on average does it take to finish a deck, stringer, transom job? I'm working on a 19' fiberglass bowrider. And like so many others the more I tare up,.... well the more I end up taring out. I figure I've gone this far want to do the job right and enjoy the boat......eventually.:rolleyes: Just curious what your experiences have been. By the way, i've done enough taring out to learn to hate fiberglass, will the itch never end!
Re: survey.. how long to finish
i did a complete rebuild in 3 weeks, stripped hull to water. i've also taken 6 months. set an outline what has to be done, then break it down to small task, then you will see the progress, and not get discouraged. i just drug one home today.
joy
Thats a good idea, I've ordered in the supplies I need (that I know about this far) so I don't have anything slowing me up. Right now its an after work project, but I have a couple weeks off coming up and I wanted to get it knocked out then. I have pictures I'll post along the way, or sooner if I get stumped.
jonesg
I'm planning on allowing 2 months, I'm ok with glassing but not experienced with boats. But I plan on a complete deck ripout from the get go rather than pecking at it only to find more rot ....bit by bit.
My mechanic quoted me $1100 for balljoints in my E350, I did it for $150, he quoted 6 hrs, it took me almost 3 days.
I expect it will be the same with the boat simply because its my first time around.
Just get cheap ($15) disposeable tyvek suits (zippered with hood) to keep the fibres off you.
http://www.safetycentral.com/tyvekcoveralls.html
A 4" Hilti diamond masonry steel disc might produce less dust than a grinding disc for quick removal. I made a lot of fiberglass molds, and used these discs with sucess. They cut like a hot knife in butter.
http://www.youtube.com/watch?v=7S0PfDU0q6I
If you have airtools, check this out, make glass cutter blades for pennies from hacksaws.
Notice the lack of dust when cutting.
http://www.youtube.com/watch?v=GoXWztxKBJI&feature=related
30 grit sanding disc are great.
jonesg
Yeh 30 grit would knock it down in a hurry.
oops!
depending on how much you tear it down........
guestimate 200 man hours.....
thats three months of 2 hrs a day.
