kennyboater
Thread starter- Joined
- Mar 11, 2008
- 95
last weekend i purchased a 1973 14ft arrow glass with an 1984-85 25hp merc. spent a few days on the motor, just got it running. now, time to turn my attention to the rotten foam, stringers and deck....
i started tearing the deck out, stringers, foam, and whole deck are completely rotten.
1. what foam do i use to replace my water logged rotten foam? (there is not much)
2. when i put new stringers and deck in, i have have to fiberglass them in?
-can i just use some construction grade adhesive to hold stringers in?
-what type of wood do i use for stringers?
3. per q 2, if i do need to fiberglass stringers in, do i use cloth or mat? what type of resin?
4. after stringers are in, either using adhesive or fiberglass, what type of plywood should i use for deck...pressure treated, marine...?
5. for plywood deck, do i have to fiberglass it in? if so, mat then cloth? I do not want to be covering with carpet, so how do i get that finished look?
6. someone told me that instead of fiberglassing the plywood deck, i can use something called lizard skin and paint it on? ever hear of it?
i have been reading on this site, and i see that rotten deck and stringers are a common problem.
thanks in advance
thanks in advance
