Seat foam selection and snap caps question....
KewlBird
Hi, I am in a process of getting materials needed to redo the interior of my newly acquired boat. I found the seats and vinyl I want in it. I will need to replace wood on the bow seats, which I plan on using treated plywood (any better ideas?). Now, the question is what kind of foam I need to use for the seats/backrests? I went to Jo-Ann fabrics and they had some foam that is green, will this do?
The second issue I have is the snap cap screw covers. Can I get ones covered with vinyl like factory or are plastic ones the only ones available? Is there ones that I can make with same vinyl I have? I've seen all kinds of plastic ones but none like original ones. Thanks.
Re: Seat foam selection and snap caps question....
i use 2" foam just the regular off white stuff. pressure treated eats metal fasteners. use exterior and paint first.
KewlBird
That's good news I need a few 1/4" thick pieces for the backrests so I don't have to buy a 4x8 sheet :D. What kind of paint would you recommend? Would any kind of exterior wood paint work?
KewlBird
Thanks Tashasdaddy you always have an answer :) , you should set up an 1-800 number for technical support :D.
erikgreen
Nah, he'd have to charge for that :)
Just my 2 cents worth, Jo-Ann fabrics does have a type of foam meant for patio furniture that would probably work very well for boats. Expensive, though.
Erik
Robj
When I redid my seats, the upholsterer just re-used the old foam. The wood was rotten, but he just steamed the old foam and it was OK. Foam gets expensive and if you can re-use the old stuff go for it.
Have a great day,
Rob.
yes, i have reused foam also. check out this site, super fast service, had my order in 3 days. also was the cheapest if found. clik shop on line. http://www.buyfoam.com/
