1956 johnson, need parts
gregorymp
I just got a 1956 johnson 15 hp, model number fd 10 l. I am having trouble finding parts. Any good web sites?
Re: 1956 johnson, need parts
what parts do you need? laingsoutboards.com that's a great motor by the way.
gregorymp
just getting started i need the 3 prong fuel connector and eventually i will need a prop shaft and the lower housing unit, this was missing when i got the motor.
wbeaton
Look for a complete used lower unit. It will probably be cheaper than buying the housing and prop shaft and you'll have a spare gear set to boot. That lower unit was used on the 10 and 18 hp from 1956-1959. I think there was a change in 1960, but it may be possible to use a newer LU from the 1960's. I don't have my books in front of me right now, but I'm sure someone else will come along.
Check eBay, post an ad on craigslist, or post a free ad over at AOMCI.
67Johnson6HP
That's way too much trouble to go through. I'll take it off your hands.:D
samo_ott
BTW, the 3 prong fuel connector that's on the hose is quite expensive. Over $100 at a dealer. It's easier to find a whole tank used with hose for $50 or so. As for the 3 prong receiver that goes on the engine, I dunno how expensive they are. They seem to be needed a lot less.
rjezuit
There are a couple of old 15HP Evinrudes on Ebay right now. Except for the covers, the mechanicals are identical. Rick
tmcalavy
Saw the fuel prong connector there the other day, too. Less than $20. PM me and I'll email you the Parts List/diagrams for the 57 FD-11, same motor (almost) but makes 18 hp.
kbait
a guy in hackensack mn called tim's outboard usually has what I've needed for 'hard' parts and I get tuneup parts from napa (sierra parts) or local marina (brp replacement). Good luck. Git'r running and she'll keep on going!
