martysauer
Thread starter- Joined
- Jan 23, 2007
- 25
I thought that I needed a new prop because the boat would under load all of a sudden rev real high, yet slow down - so I replaced prop, and then it happened again, and I was thinking that I was slipping out of gear somehow. But as I was diagnosing the issue (while on the lake), eventually the engine started squealing (from the flywheel), and almost making a grinding noise and eventually wouldn't start back up. The flywheel almost feels hard to move at some points, and then it will seem to move freely, but I'm not hearing any pop from the valves (while the plugs are out) - in other words, at some points there seems to be no compression and then full compression. Could the issue be a woodruff key? If so, why the squealing (if you have a guess)?
Thanks,
Marty
Thanks,
Marty
