bigdawggie
Thread starter- Joined
- Jan 12, 2008
- 51
Hello,
I am going to attempt to replace my impeller by myself. I have an outboard 77 merc 1500 and did a search online at mercruiserparts. I have a few questions,
do I need to replace anything else on the shaft besides the impeller?
I am pretty good at fixing things but is it difficult to do?
are there any special tools required?
below is a list of parts that are on the shaft which holds the impeller they are in order of bottom of the shaft to the top. please letrme know if I should replace any of them as well
-bottom of shaft-
gasket
o ring
oil seal
oil seal
base assy
pin-dowel
gasket
faceplate
gasket
key drive
impeller
insert
body assy-wp
washer
lockwasher
screw
washer
nut
seal
sleeve
-top of shaft-
thanks
-bottom of shaft-
gasket
o ring
oil seal
oil seal
base assy
pin-dowel
gasket
faceplate
gasket
key drive
impeller
insert
body assy-wp
washer
lockwasher
screw
washer
nut
seal
sleeve
-top of shaft-
thanks
