impeller replacement by myself
bigdawggie
Hello,
I am going to attempt to replace my impeller by myself. I have an outboard 77 merc 1500 and did a search online at mercruiserparts. I have a few questions,
do I need to replace anything else on the shaft besides the impeller?
I am pretty good at fixing things but is it difficult to do?
are there any special tools required?
below is a list of parts that are on the shaft which holds the impeller they are in order of bottom of the shaft to the top. please letrme know if I should replace any of them as well
-bottom of shaft-
gasket
o ring
oil seal
oil seal
base assy
pin-dowel
gasket
faceplate
gasket
key drive
impeller
insert
body assy-wp
washer
lockwasher
screw
washer
nut
seal
sleeve
-top of shaft-
thanks
bigdawggie
Re: impeller replacement by myself
P.S. I don't have a manual and am yet to find one for my motor.
dalton565
make sure when you take the old impeller off you dont loose the
key that lock it onto the drive shaft. i made this mistake the first time i dont it but lucky enough the key fell inside the gear casing and i was able to retrieve.
As a result the impeller wont spin so no water will be pumped. Other than that its pretty straught forward, few spanners and a socket set and you should be able to manage it.
R
cannonford57
mercuryman,u can get a manual from basspro,west marine or any reputable marine dealer in your area...two publishers are either clymer or sealock...lots of illustrations and diagrams to work with...gaskets are a must to replace,also take a hard look at the housings,,,depends just how "hot" it was ran..if the material looks melted on the outside it probably needs replacing///any questions u have i'm sure someone here can help ya....good luck
