jeff_smith_0423
Thread starter- Joined
- Dec 5, 2007
- 492
Greetings all.
With a lot of help from folks around here, I sucessfully revived my 1977 Mercury 850. Plugs, carb rebuild, trigger wire repair, switchbox, fuel pump rebuild, and under-cowl fuel lines.
I decided to have a marine mechanic handle the impeller change, control cable replacement, and the link and sync. $480 later, I've had the boat in the water twice since then. First time out, it was between 48-50 degrees. The motor would start and idle fine in at the dock, but stall out when put into gear unless i really gave it some gas while engaging fwd gear. I was easily able to plane the boat and achieved pitot indicated speeds of 32-33 mph in a pretty decent chop
Yesterday, it was between 65-68 degrees, and I could not get the motor to maintain an idle at the dock without the fast idle lever up. I was still able to manage to get it into gear, plane the boat at 34mph pitot indicated. I could probably continue using the boat like this, but it's just hell at the ramp trying to manage keeping it alive, lining up with the trailer, and loading.
When on muffs, the motor kicks over and starts with half a crank, easily engages fwd and reverse. Compression is good and I've got good spark.
I do not currently have a tachometer. I know that I need one to really diagnose this problem but I need suggestions as to what i should buy. I suspect that my "marine mechanic" didn't do the link & sync under proper load - he said he did, but at most, it was in a small test tank. I've toyed with both increasing the idle speed and fattening the idle mixture - although he told me it was pretty fat to start with.
Any suggestions on potential troubleshooting tips OR about installing a tach? I'd prefer to connect the tach to the tach plug on my MerControl box if at all possible.
