i386
- Joined
- Aug 24, 2004
- 3,548
Re: Running plywood through a planer
I've never used one of those big belt sanders but I would have thought 1/4" was a little much to sand off. But yea, a few passes and it would knock it out I bet. I was a little reluctant to drop it off somewhere and wait a week for them to get around to it.
Yup
That was my "plan c" if nothing else worked out. In hindsight, that method would probably take about the same amount of time as the router.
Better late than never, but a suggestion I would have made would have been to go to a cabinet shop and ask if you could reduce the thickness using their "time saver". Essentially a large belt sander with a belt feed. You just run it through a few times and you'd have it done. If they had a decent grit belt, you'd get a nice surface for the resin/fiberglass to adhere to. Cabinet shops probably aren't really busy right now, throw them 20 bucks or a case of beer and I'd bet you'd have no problems getting it done. No chance of hurting the sanding belts as long as you didn't try to force the board through unless you were going to hit anything metallic ( which would groove the belt rendering it useless ).
Glad you got it fixed.I was going to suggest a circular saw as well if you could make up a jig to rest the saws foot on that surrounded the piece that needed resizing.I would have crosshatched it and used a wide wood chisel to chip out the sections,light sanded it if needed and be on your way.
Hopefully you had some scrap that you could experiment on)Ron G
Yup
