Where to install tabs
ralphy670
Here is a picture of my transom. I am not sure how to mount smart tabs on it. Any info would be appreciated. Thanks.
a70eliminator
Re: Where to install tabs
Now thats a no brainer you only have one option and it's looks good right exactly where your tiedowns reside, you'll just have to relocate them that's fairly easy to do.
Pierutrus
Owe...and make sure you tell him how to put KEEL GUARDS on.
Lot's of love of course....
rndn
Why can't they be put on out farther away form the tie downs? Do you have a picture of the entire transom? Do you have room to mount them out farther?
Jdeagro
iboats.com Partner
Ralphy;
Check your email I sent you an answer. Let us know how it works out.
handman64
Ralphy,
Please post pictures when you complete this. I have the same situation and need help resolving it.
Pierutrus
a70eliminator,
You know I'm just messin' with you?
No hurtin' intended!
always love.....
Boatist
I would not install where your tie down are, just too close to the engine.
Do you have a pictures of the hull form chine to chine. Normally you want them a inch or two in from the chines but if that part of the hull is also stepped above the water then they would not work. At that point the only option would be near you tie down but at far form the engine as you can and still have the actuators clear the hull. You would not be able to use the tie downs.
Bodega Bay Weather on May 2 08 Improving Launch but watch the weather.
Winds NW 310 degrees true at 25.3 knots with gust to 29.2 knots
Seas 6.2 feet with swells every 16 sec and chop every 4.6 sec Sea Temp 49.1 degrees.
http://www.ndbc.noaa.gov/station_page.php?station=46013
