Re: Where to install tabs
I would not install where your tie down are, just too close to the engine.
Do you have a pictures of the hull form chine to chine. Normally you want them a inch or two in from the chines but if that part of the hull is also stepped above the water then they would not work. At that point the only option would be near you tie down but at far form the engine as you can and still have the actuators clear the hull. You would not be able to use the tie downs.
Bodega Bay Weather on May 2 08 Improving Launch but watch the weather.
Winds NW 310 degrees true at 25.3 knots with gust to 29.2 knots
Seas 6.2 feet with swells every 16 sec and chop every 4.6 sec Sea Temp 49.1 degrees.
http://www.ndbc.noaa.gov/station_page.php?station=46013
