Re: I wanna go faster
I am using the speedo on the dash. I don't have a fish finder w/ speed on it. I am feeling that the 17 may raise the rpms to the 4200 range. I am also using the tach in the dash to.. The timing is set, and new plugs, wires, dist, and rotor are all new. I replaced the Head and Intake/exhaust manifold. all the valves are adjusted and it runs real smooth. But I'm the 3rd owner of this boat and when I tore into it I found that they used a merc 3.0 head with larger ports and a pretty bad match up but it did run and sounded good? needless to say it has all the correct pieces now. I didn't mess with the carb at all I was thinking maybe that would help but Ive never tuned a carb its a 1994 holly 2 barrel carb. Thanks for all the input so far you guys ROCK..
