need some help.last year the motor was sneezing and stalling at idle and sound the fuel restriction alarm at wot.i found the fuel line was rotted and replaced it and bulb with factory repl.also found one torn oring that goes between the carb and throttle plate and replaced it. went to the lake yesterday and the primer bulb would not get hard at all.it only took two sqeezes at the house on the muffs.the only thing i did was put more fuel in the tank which was difficult while gas was spitting back out. the vent line is clear and the pickup tube was also replaced. i fixed the idle issue but the restriction alarm went off again. when it went off at wot a friend reached back squeezed the bulb and the alarm quit but the bulb collasped when he did this. the siphon valve has been eliminated.
