steveo32
Thread starter- Joined
- Mar 15, 2008
- 60
Ok I have the green coating from the stator melting down the engine from under the flywheel. How do I determine whether it is the stator or the recitifier. I have read numerous posts and that is how I found out that the recitifier is also a common reason for the green coating on the stator melting. I have no loss in power and no other signs that it is faulty. I have only had this boat and motor for a couple months, so it could of been replaced. I thought at first it was grease or something but now suspect its not from the posts I have read. I have a manual, so should I take the flywheel off and see if the green coating is melted or not before I buy anything. Also what kind of affects should I be seeing from the stator coating melting enging wise? I haven't had any problems starting besides bad gas that fouled the plugs. But it runs fine know with fresh gas and clean spark plugs. I took it out today and it doesn't appear that the greeen coating is dripping down anymore, but does feel a little tacky on the engine, I assuming this is from the heat of the engine. Thanks for the help.
