bronco_head
Thread starter- Joined
- Jun 3, 2008
- 6
Can any help? I have a 1990 Johnson GT engine V6 and the problem I am having is that I can run my motor around 3000 RPMs and it rune fine but when I run it wot the steady alarm goes off and I can not go past 3000 RPM motor shakes like it missing. Haft to stop run on idle alarm goes off.Motor still will not go over 3000rpm.I have to turn off motor and wait about 20 min or so and then it runs 3000rpms,But if I run it wot it does it again. I checked compression fine, not running hot around 180, pulled apart temps sens still alarmed. Could this be a VRO problem,seems to still pump oil and gas but on wot maybe its getting weak and cant keep up. Dont have anything to check the VRO pump pressure. Does anybody have any thoughts on this or what the problem may be. Should do away with oil to the VRO and just run premix threw the fuel part.
